239
- April 4, 2011
- Bonita Springs, FL
- 2000 XLT, V6 OHV
Back in 2015 my heater hose broke and caused my vehicle to overheat, and I’ve replaced every gasket down the lower intake since then, due to leaks. I started getting a misfire(p0304) a few months ago and was losing coolant. I added some k seal and it went away. I drained the radiator to get rid of any leftover k seal and the misfire came back, until I added more k seal. Well, I took the truck in for a compression test today and it passed. But I’m still getting pressure in the coolant system when the truck is cold, such as coolant pouring out when I remove the radiator cap or bubbles forming in the reservoir tank. I’m wondering if the exhaust could be leaking into the coolant, even though the coolant isn’t getting into the cylinder. Any advice would be appreciated before I pay to have the engine dismantled to replace the heads/head gasket. I’m wondering if the exhaust is still somehow in the system and needs to be released. Sorry for the long read. Thanks.
