will the cast headers from a 99 fit in a 98 5.0 .also what the last year they put 5.0 in the explorer? would a 2001 go in a 98 or are there big changes? thanks!
The only major difference is the return-less fuel system that started in '99. The cast manifolds should bolt right up. Your best bet is buy the Torque Monsters and be done. The stock manifolds both steel tube & cast are biggest restriction in the exhaust system.
