JPM
- September 27, 2001
- Ft Lauderdale FL
- Explorer 96 Eddie Bauer
Right headlamp and also fog lights will not operate. Both are on same fuse. Right headlight works only in high beam mode. Fuses OK and Bulbs OK.
Have been using higher watt headlight bulbs.
UPDATE: Had everything checked out. Put back correct watt bulbs. Dealer found "Lamp out warning module" defective. Replaced module and everything works OK. FYI the part number is F77Z*10K910*AA
