justchecking
- April 20, 2008
- Lebanon, Ohio
- 2002 XLT V6 2WD
I just noticed this. When the headlight switch is in AUTO and the headlights come on, the message center and radio displays dim as they should. HOWEVER, if I put the headlight switch manually to the ON position, the message center and radio displays go out.
I assume that the dimmer circuit is running through a different path in this case, but what could it be? Couldn't spot anything on the wiring diagram.
Thanks in advance if anyone has any ideas.
