Robbbyr
- February 28, 2014
- Akron, OH
- 2014 Explorer Sport
2014 Sport, very recently had right side headlight quit. Bulb good, fuse good, just won't work. Tonight driver's side went out too! Re-checked both fuses (#16 and 17) under dash (what a pain!), both good. Then discovered something very odd by accident. If I disconnect the negative battery cable, when I reconnect it the headlights both momentarily flash! Obviously the wiring and bulbs are intact, something is just not passing current normally. The headlights are the only thing I can find not working. Bu the way the high beam shutters are working even though the bulbs aren't on.
Any ideas? Body Control Module? Any way for me to "reset" it if that is the suspect? Thanks!
