I saw the guys on Spike TV doing the "Poor Man's" Headlight renewal. So, instead of paying 20-25 bucks for a "Kit". I decided to give it a try. All I needed to buy was an applicator pad(2 for $1.79 at AZ). I had the rest of the stuff on hand. The other things you will need is 1500 grit wet/dry sandpaper, and any good rubbing compound.
This is what I stated with:
http://s955.photobucket.com/albums/ae39/scottv38/?action=view¤t=DSCN2960.jpg&newest=1
I sprayed the headlight and paper with a lot of water first, and just started sanding. It took quite a while since the build up of junk was think. After about 20-25 minutes of sanding, I sprayed water on headlight to clean it off and wiped with rag. For the next step, it would be easier if you have a power buffer, but I don't, so a lot of elbow grease was needed. Get an applicator pad damp, and get a good amount of rubbing compound on there and once again... rub like crazy in circular motion. I kept adding more compound as it fell of to keep it gritty. After another 10-15 minutes of rubbing, this is what I got:
http://s955.photobucket.com/albums/ae39/scottv38/?action=view¤t=DSCN2967.jpg
I did one headlight first, and then turned my lights on as my Ex faced our wood fence. The one that was cleaned was bright against it. The one that was not cleaned, I had to go up front to make sure it wasn't out! That big of a difference!
