KS_Explorer
- April 25, 2014
- 1994 Explorer XLT 4WD
I had to have the head gasket in my '94 Explorer replaced last November, after my less then two year old radiator blew. Then I had the heater hoses blow and ended up with two cracked heads, one may have been cracked from before the previous head gasket change. Then a week and a half after I had the heads and gaskets replaced, the passenger head gasket blew again. The mechanic that did the last head/head gasket replacement insists that I have a warped block. However, another mechanic showed me where he believes a head was dropped on the head gasket, crushing the metal 'O' ring that seals around the top of the cylinder.
I am going to check for block warpage once I can get my hands on a straight enough straight edge. (Although, I am wondering if a carpenter's square would be accurate enough.) If it is still good, I am going to have the engine put back together.
The question that I have is, what should I consider doing or checking while I have it apart?
