robbieas
- December 16, 2011
- Jacksonville, FL
- 16 Ford Explorer Platinum
New issue now that it's cold..... heat is only blowing while I'm moving. Once the car is 100% warm it works fine. If I come to a stop light, the air will slowly shift from nice warm air, to blowing cold air over about 20 seconds. once I start moving again the air slowly goes back to being nice and warm. This happens whether I'm on AUTO on climate control or if I override it and crank the setting to 90 degrees. But once it's fully warm, the climate control system works like normal, and the heat stays warm at stops.
I'm not hearing any clicking, so I don't think it's the blend door.... plus It's shifting from hot to cold so it doesn't seem to be stuck. The issue affects the rear heating/cooling system too.
Any thoughts on the issue are appreciated!
