    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
Heater blowing cold air
cduggan67
2001 ford explorer
Hello:
I have a 2001 Ford Explorer 4.0 and one minute the heat was blasting the next thing it was blowing cold air. I've changed the thermostat, water pump, flushed the entire cooling system and it's still blowing cold.
Any advice on what I can try next or what you think the problem is?
It's -4 degrees here....any help would be appreciated.
Thanks.
Bobmbx
King George, VA
2016 Explorer Platinum
Hello:
Thanks.
Check your heater control valve for proper operation. It is normally located on the heater core supply hose. It is vacuum driven and shuts off the flow of hot water when the AC system is calling for cold air.
It will look something like this. Your exact location and design may vary. But it will be on the heater supply hose.
cduggan67
2001 ford explorer
Thank you!!
That was the problem! Thank you so much for your help!
