jpopp1
- November 12, 2012
- Fernley, Nv
- 01 Ford Explorer Sport Tr
I have a 2001 Ford Explorer Sport Trac with a V6. The AC worked good all summer long but now that winter is here the heater just blows air. After about 15 minutes its finally warm in the truck. I checked the blend door actuator as best I could, it was making noise when rotating the knob from hot to cold and back. Removed the glove box to gain access.
I don't think it is the actuator but something to do with a vacuum line. The temp gauge stays in the normal range during operation, coolant level is good and one hose leading to the heater core is a little warmer then the other. I have replaced the broken vacuum lines under the hood in the engine compartment but might have missed one.
Could the problem still be a vacuum line, blend door or something to do with the thermostat? Been looking through all the forums but keep running in circles. Any advice?
