On my 1991 Ford Explorer (about 248,000 miles, bought it in July 1990) The leaking of hot air from the heater into the incoming air raised the temperature of the outside air and reduces the temperature of air when the air conditioning is turned on. I complained to Ford about this about a week after I bought it and it was not until a long time later I learned about this crummy blend air design which never worked on my Ford. I cut the two hoses to the heater and installed a bypass. I used two 5/8" barbed elbows and 4 hose clamps and a short section of heater hose. When the weather turns colder in October I will use two 5/8" barbed straight sections and 4 hose clamps to reconnect the heater to the coolant flow. It seems that the coolant temperature gage reads somewhat cooler with that heater bypass installed.
