Old Tom
- March 11, 2012
- 1997 Ford Aerostar w/ 3.0
1st timer here and am hoping you all would have some insight for me in regards to a heater control valve.
A little back info on the situation.
I have had a persistent slow coolant leak for a few weeks now. After some trial and error, I managed to locate the leak to the heater control valve. Not much of a surprise that it was broken/leaking. Its factory original and is 14-15 years old, so not too upset that it finally gave up and cracked on a hose nipple and started leaking.
So i manged to remove it. It was on the passenger side over close the to fender and close to what im assuming is the A/C evaporator or some such A/C piece.
So i found a replacement part at my local auto parts place for like $18. Not too bad i thought.
So here is where we get to the puzzling part. While the replacement part looks the same as the old part, if i look at the design of the 2 parts and line them up accordingly, the vacuum valve assembly is facing the opposite direction from the original and thus getting a hose clamp of either the tension variety or the screw down kind is all but impossible.
So i thought that maybe i received the wrong part. So i did some online checking for heater control valves for my van and all the pix show the same part with the vacuum body facing towards the rear of the vehicle.
Is this right? Reason i ask is the old unit had the vaccum valve facing forward. Getting clamps off/on that is difficult but is doable. Where-as this new part . . . .i can get it in place but there is no way to get to the hose clamps to tighten them down.
Is there something Im missing? Do i indeed have the wrong part? Can i flip the vacuum valve around without causing any coolant flow issues? I will attempt to take some pix of my situation and post them here to see if that will help with both my explanation and hopefully a solution.
thanks
Tom
thanks
Tom
