JAWIT
- February 13, 2019
- Richmond
- 2008 Mountaineer V6, 4.0L
I went for a routine oil change this past weekend and my mechanic said they added about a gallon of coolant to the overflow reservoir as it was empty and there may be a leak. I thought that was strange as I had just checked it about a week before and it was near the full hot mark like it usually is. I asked if they added Zerex G05, or the Motorcraft gold, as that is what is specified. Mechanic said they added a clear (colorless) antifreeze to it that is compatible and this is the type they always add to vehicles. Wish they had asked me before adding that coolant, as the charge was $18. I could have bought a gallon of the Zerex probably for that price.
Should I be concerned and do a complete drain and refill or is a gallon of that stuff not a big deal?
Anyways, I looked around but couldn't find any leaks. The only sign of something that may have leaked was some evidence of dried coolant deposits near the heater control valve. I figured the one on my vehicle was probably original and wouldn’t hurt to change it out since I have read about them failing and leaking. I ordered a replacement Motocraft brand ($25 on Amazon) but those damn factory hose clamps were a pain to release and slide back on the hose in order to get the old valve off. I finally managed to get the new valve installed and hose clamps slid back into place after a while and started the vehicle up, and wouldn’t you know, the lower hose started leaking. I got fed up with the lower clamp and just put on a worm gear style clamp next to the factory clamp one and that seems to have fixed the leak. I’ll keep an eye on the level. I suppose I could have it pressure tested to make sure the leak isn’t somewhere else, but I see no evidence anywhere else and no coolant smell. I checked the radiator and didn’t see leaks there either.
When the vehicle is cold, having sat overnight, should the coolant level in the reservoir be down near the bottom at the cold mark? Mine never is is that low and is always closer to the full hot, maybe an inch or so below. The mechanic had filled it up almost to the lid on the reservoir and I siphoned some out since I felt he didn’t leave me any expansion room with it filled like that.
