Deathwish657
- January 4, 2012
- Georgia
- 1995 Ford Explorer XLT
Hello, I’ve been reading up on this problem a lot, trying to figure it out, researching it like crazy, asking a lot of people about it, just is not finding an answer for it.
Problem: With the heater on, Temp Gauge will fluctuate (Go up above Half, down to just before the C.), and every now and then there is a ‘Thumping’ noise.
Components to Eliminate: Water pump, Radiator, Thermostat (Which, Yes. It is in the right way.), All hoses (Upper, Lower, Heater hoses), Heater control valve, Idler pulley, Idler tensioner
This is a list of ALL I have already replaced while trying to figure this problem out, which hasn’t fixed it just yet.
List Starts Now:
1.) Replaced Water pump.
2.) Replaced Radiator.
3.) Replaced All Hoses (Upper, Lower, Heater Hoses)
4.) Replaced Heater Control Valve
5.) Replaced Thermostat
6.) Replaced Idler Tensioner
7.) Replaced Idler Pulley
8.) Thoroughly flushed entire system, checked heater core for leakage. (Nothing found)
9.) Replaced Radiator Cap
With that all said, I was going to replace the heater core, but looked into it further before messing with that. (That’s a hell of a job…) Known symptoms for heater core failure indicate leakage of anti-freeze to passenger side floor, windows left with a filmy texture, smell of anti-freeze. I have had None of these, so I’m eliminating the heater core out.
Other possibilities: Exhaust Manifold Gaskets, Intake manifold gasket bad.
Note: There is no sign of blown head gasket, since there is no coolant in the oil, no oil in the coolant so I’m sure that isn’t a cause for it.
If anyone happens to have any other suggestions, that would be helpful.
I am going to Pressure test the cooling system soon, do a compression test as well.
After all of this, I don’t know what else to do anymore.
List Starts Now:
