snyd20
- July 17, 2012
- Ohio
- 1996 Ford Explorer XL
I'm not sure if my heater core is going bad or if there are external lines on the outside that could be going bad. Why I ask this is because I was told if the core itself was going bad it would leak inside my Explorer, this isn't happening, at least not as of right now. However it does steam pretty bad when I run my defrost and it slightly steams when I run just the heat. Since the issues seem to be primarily under the hood that is why I thought maybe there were some lines or hoses that could be bad. It seems to me that the antifreeze/coolant is leaking onto the exhaust(or something else that is hot) and causing the excessive amount of steam. Or am I just being overly optimistic and it's the whole heater core going bad? Any help or input would be greatly appreciated, as I'm obviously just a novice and I also can't afford to pay roughly $500 to have it replaced professionally.
