heater core replacement | Ford Explorer Forums - Serious Explorations
lorraine1
wva
98 ford explorer
hey guys is there a link with photos on how to replace the heater core on a 98 5.0 AWD,mine went south.i hear their a nightmare like the s10"s.thanks
Basically, disconnect the whole steering column, like this
attachment.php
Do not pull the steering wheel ( like the ford service manual says to)
remove seats and center console.
This gives you the room to remove the dash , you do not actually need to remove the dash from the truck, and with the seats out of the way you'll have room to slide the dash back far enough to access the heater core.
attachment.php
attachment.php
This thread has some info
http://www.explorerforum.com/forums/showthread.php?t=173650
and will link you to this one
http://www.explorerforum.com/forums/showthread.php?t=143617&highlight=heater+core
This one will help also
http://www.explorerforum.com/forums/showthread.php?t=342778&highlight=heater+core
There is also a series of videos on YouTube if you google YouTube heater core remove replace explorer. Covers all except the hidden bolt behind the engine/intake that is not easy to find/remove/replace
Thanks man. Helps a lot!
