HuskerWebhead
- January 29, 2013
- 2002 Explorer XLT
It would appear that the "Off" position on my environmentals dial doesn't work. I can progress through all 4 levels of speed, but when I turn the vent position dial to OFF, the fan stays running. I can even cycle through the different speeds and it changes. If I leave it in the off position and turn the truck off then start it again, the fan is no longer running. It's just when I actually turn it on then attempt to turn it back off while the engine is still running.
Could this just be a dial issue, or is there a bigger problem?
Also, it would appear there is no difference in fan speed between 2 and 3. I'm not sure if there's supposed to be a huge difference or not, but I'm not feeling any change.
Thanks!!
Thanks!!
