Heater Hose Part Numbers? | Ford Explorer Forums - Serious Explorations
azstang
Tucson, AZ
2000 XLT 5.0 AWD
I've been searching for this without any luck. Thought for sure someone would have had this same problem before.
I'm going to replace all the hoses when I do the water pump on my 2000 5.0 here in a few weeks. Does anyone have part numbers for all the different heater hoses? Rock Auto shows several different ones, but hard to tell if they're the right ones for the 5.0 or not.
Thanks,
Shawn
Just go to your nearest parts house and buy the hose in bulk, cut it to the length you need. If you want to keep with factory hose, go to your nearest Ford dealer.
I bought the three piece set from the local stealership when I did the water pump on mine, I will go see if I can locate the PN's in the morning. I think the tags are still on there.
I'm pretty sure they have to be molded hoses as they all have tight bends in them on the 5.0. I don't shop for parts local anymore unless I absolutely have to. Between the jacked up prices and the 10% sales tax I've found it much cheaper to shop on line for all my parts.
Thanks. I appreciate it.
Shawn
If you use the rock auto interactive catalog, it pulls up the ones that will fit.
There was one bypass hose (the red one) that I had to get locally (length of hose cut) since I didn't want to wait for the Motorcraft from Rock.
Check my radiator thread for the part info: CLICK
Shawn
Sorry dude, between a half marathon this morning, two soccor games and an end of season party, I never looked under the hood. Tomorrow morning.
3 of them;
All are labeled KH-202
then, the longest is F77Z-18472-JC
The middle is F77Z-18472-KB
and the shortest is F67Z-18472-BB
