I'm working with a friend on designing a heavy-duty steering for his explorer, using 3/4 ton tie rod ends, a drop pitman, and a reamer to re-taper the holes.
Has anyone done this? We talked about the superrunner steering kit, but the only way to get parts for that puppy is from Superlift.. which is no good if you break a tie rod end in the middle of no-where.
I am thinking of switching it from an inverted-Y to an inverted-T, using a combination of tube to make the tie rod and drag link.
