JustBill
- October 27, 2019
- 2005 Explorer XLT
I have a issue that has me scratching my head BIGTIME. Let me say that I spend 14 years in the tire and auto service business. I was never an engine tech, but I was a mechanic (primarily brakes, front-end and suspension. I have been diligent on maintenance with this vehicle. So here's what's happening:
About a week ago I had a "no-crank", (so NO start) issue. This was the first start attempt in the morning and it did follow a night of our coldest weather of the season...low of about 35 deg. Lights and other accessories worked, but no sound (clicks) at all. I tested the battery, it was basically fully charged..but I charged it for a bit anyway....performed load test and it passed with no issues. Even did back to back load test and it read perfect.
I pulled the starter relay out and swapped it with the blower motor relay as it was identical. Then it started perfectly...popped right off and ran great. Of course I assumed I had found the culprit. The next day, I got a new relay and put it in the empty blower motor spot. And thought all was good, until (after sitting over night again) it did not start, same issue, no clicks. PLEASE NOTE...THIS issue is and does relate to the engine temp, being either cold (no start) or at operating temp...it starts perfect every time! Here's what I mean - I arched power at the starter solenoid and it started ( yes, I thought once again I had found the problem) I left it running for about ten minutes. Then I shut it off and restarted. Perfect START without arching the solenoid. But the engine was warm. The rest of the day, I went and restarted it 10 times! Leaving about 40 minutes between start attempts. Every time is was perfect...but again with a warm engine. The next morning...with cold engine...SAME ISSUE, no crank. I decided to check connections at the solenoid. I removed power & signal wires. They appeared fine. I then put them back on....AND it STARTED!! That's all I did, remove wires and re-connected them. Same deal, started all day with a warm engine. Next morning, no crank. To me it seems apparent that the there is some type of "Re-Set" that is occurring when I disconnect the battery and perhaps even the solenoid wires. If I do this, it starts...and will each time after that IF the engine is warm. But when it sits overnight, I'm back to original NO CRANK issue.
Man I hope some one has gone through this one before!! Thanks in advance and I cannot wait to see thoughts on this.
