julietaylor
- January 9, 2008
- Portsmouth, VA
- 92 Explorer XLT
Hello everyone, new here to this site, but I need help!!! I have a 92 Explorer XLT, i was driving home doing about 65mph, when the engine cut off, I had power(lights on, radio still on), after about a minute it started right back up, drove for about 10 minutes, got off the highway, stopped at a stop light, truck still running, came to another stop light, made a left, came around a corner made a right. As I was slowing down to make the right, truck stalled out again, restarted, and continued my trek home, slowed down to take on a curve, trucked stalled again, started back up, engine sounded BAD, running very rough, shaking horrible, making loud noise, pulled into to driveway, put in park, truck ran but by the looks and sounds of the engine I thought at any minute it was going to fall out on to the ground because it was shaking so badly. Since this has happened, I have replaced plugs and wires, checked fuel pump(it's fine), all fuses and relays appear to be working, inertia sitch fine, pcv valve fine, new air filter. After all this truck would start and run, sounded great, but then would cut off after about 15 minute in idle, now truck won't start at all, unless i spray starting fluid into air intake, the minute I stop sparying, my truck cuts off, when i am spraying the fluid in and pressing accelorator, engine revs normally, but again the minute i stop spraying, and continue to press accelorator lightly or pedal to the floor, eninge stops. Some one please help!
