01 sport trac
I keep throwing a P0401 code and I have replaced everything I know to replace on the EGR system....valve, vacuum regulator, sensor....am I overlooking something? Even used a can of Sea Foam to clean things out. Tubes look good, idle is not rough. Sometimes at road speeds it will run a little rough. Each time I've replaced something CEL will go off for a time and then come back on with same code showing. Have to pass emissions to get new tags and I can't get this thing fixed. Help!!!!!
