julesverne
- February 1, 2018
- Warrenton missouri
- 2006 Ford Explorer 4.0
Hi all! I’m hoping someone can help me. I have a 2006 Ford Explorer XLT 4.0 that is having issues with the alternator. It’s not kicking on to charge the battery. Here are the test I have performed so far.
Battery Test 12.7 Volts
Load test Battery 11.9 Volts
Alternator B+ ( at main terminal on Alt) 12.Volts/oms got OL)
3 Plug connector (while unplugged from alternator) Black wire 4 to no Volts and no continuity on tester—got no red light. Yellow wire got 12V and passed continuity test.
Check engine charging system light is on and battery light on dash is also on.
My question is this a fusable link issue and if so where are they on the wiring harness? Or is the an Alternator or PCM issue? Or maybe the 3 plug connector is bad? I am confused on what to check next to isolate the problem.
Thanks in advance for any help!
