Carrie 42
- March 15, 2009
- Hodgenville Kentucky
- '93 Ranger 6cyl manual 4x
Hi, I'm new!!
I have a 93 Ranger and i am having problems with the clutch I think. When you shift into third fifth or reverse you have to jamb the clutch pedal to the floor and have to force the shifter into gear,it grinds sometimes to like your not hitting the gear. When you shift into first second or fourth you can barely press the clutch pedal and it will shift if you push in to far it winds out,I also have to force the shifter into these gears sometimes. Could it be the clutch or just a part in the clutch system out?
