help....98 tranny in a 99
project92
missouri
00E.B.,93 xlt 92 xlt
okay put a motor and tranny out of a 98 (less miles and remanufacter tranny)
the new tranny didn't have the rear speed sensor so I found the sticky about the wires so we used a paper clip took the open loop code out but tranny wont shift out of first did fine in the 98... I searched for a hour through stickys and the search engine any body got any advice?????
little history the truck abs is on but old tranny shifted fine (just had the od problem) guy slung a rod (30,000 miles oil changes not 3,000) so he bout a wrecked 98 with less miles and a new remanufactured tranny...to put in his 99
any help is apprecated...thanks
O Help with tranny identification. Transmissions & Transfer Cases 10
C Newbie 95 Ranger tranny help Transmissions & Transfer Cases 1
bigred4x4 Need help with tranny cooler Transmissions & Transfer Cases 0
dustinjorge 5R55E, Tranny Guys are Stumped, help? Transmissions & Transfer Cases 7
H 03 Ford explorer tranny help!! Transmissions & Transfer Cases 5
B Please help tranny trouble Transmissions & Transfer Cases 6
G 2002 explorer tranny help please Transmissions & Transfer Cases 9
M help me please sheared the output shaft off manual 4x4. tranny Transmissions & Transfer Cases 6
J Tranny won't kick down. HELP!! Transmissions & Transfer Cases 0
N Ford Explorer Tranny Issues Please Help!!! Transmissions & Transfer Cases 0
1 Another tranny thread on my 96 Explorer...please help Transmissions & Transfer Cases 4
G tranny help Transmissions & Transfer Cases 5
M rebuilt my tranny same issues,plz help Transmissions & Transfer Cases 8
T Help, cant tell if clutch is bad or tranny is shot. Transmissions & Transfer Cases 3
S help 4r44e tranny Transmissions & Transfer Cases 2
gsx220 Need Help! Possible tranny issue? Transmissions & Transfer Cases 20
N Help possible tranny failure Transmissions & Transfer Cases 2
F Need a little tranny help Transmissions & Transfer Cases 1
S 200,000 mile + A4LD Tranny just starting to act up, need help! Transmissions & Transfer Cases 4
X Tranny Quit? Please help! Transmissions & Transfer Cases 2
L Manual tranny swap HELP Transmissions & Transfer Cases 1
F tranny help Transmissions & Transfer Cases 3
D Tranny help Transmissions & Transfer Cases 1
B Need help with a tranny swap in a 99 XLT Transmissions & Transfer Cases 0
S ranger tranny HELP Transmissions & Transfer Cases 0
R HELP! 02 explorer 4.0 4x4 no reverse..06 ranger tranny?? Transmissions & Transfer Cases 1
D Help with tranny Transmissions & Transfer Cases 2
P $1500 overhaul on tranny, 4 days later its slipping worse!!! please help!!!! Transmissions & Transfer Cases 5
R A4LD Tranny Issues--Help? Transmissions & Transfer Cases 4
J Help with TC/Tranny Diagnosis Transmissions & Transfer Cases 0
M HELP.....97 explorer 5.0 tranny issues Transmissions & Transfer Cases 8
M 99 Tranny Help Please Transmissions & Transfer Cases 2
N Tranny swap help... Transmissions & Transfer Cases 1
E 2nd Installed Tranny Same Problem HELP!!! Transmissions & Transfer Cases 4
G Quick tranny help needed...in trouble Transmissions & Transfer Cases 1
blueka Tranny Help Needed.... Transmissions & Transfer Cases 16
D Tranny quit with no warning.I need help. Transmissions & Transfer Cases 26
4 need tranny help Transmissions & Transfer Cases 0
J t-case/tranny problems? help please? Transmissions & Transfer Cases 2
N Help Nitro with manual tranny! Transmissions & Transfer Cases 6
F Need help with tranny issue!!!! Transmissions & Transfer Cases 13
9 95 Explorer w/ Tranny problems, please help! Transmissions & Transfer Cases 10
Z need help with tranny install Transmissions & Transfer Cases 4
R Tranny help Transmissions & Transfer Cases 2
H Tranny swap. Need Help. 4sp automatic Transmissions & Transfer Cases 1
chad551 Tranny Help Transmissions & Transfer Cases 0
C 2002 Explorer tranny problem (Would appreciate some quick help please) Transmissions & Transfer Cases 7
J Rebuilt tranny, now 4x4high flashing help me pls Transmissions & Transfer Cases 1
R '91 XLT tranny help! Transmissions & Transfer Cases 4
GTexplorer Help tranny issues! Transmissions & Transfer Cases 7
Similar threads
