93XJason24
- August 15, 2005
- Ft. Worth, Tx
- '93 explorer
I need some help.. Just got a '93 explorer.... Check engine light was on. It threw a code 22: MAP (Manifold Absolute Pressure) sensor & code 122: TP (Throttle Position) sensor. I've located the TP sensor but not the Map sensor. Anyone have an idea of What I could do to get away from replacing both and where I might be able to locate the map sensor? Something else... Other than routine maintenance on the explorer (fluid changes.... Grease... etc...) Anything I need to look to change? All input is appreciated...
Thanks for your time
