Swifty Morgan
- May 9, 2019
- Location
- FL
- City, FL
- 2016 Explorer Limited
I have a 2016 Explorer Limited. During the last month or two, I've seen drops of water falling from the overhead console twice. I contacted a glass company, and they told me I probably had plugged drain lines.
Problem: I can't access the drain lines to clear them. My slide motor works, but the motor that works the glass is not functioning.
The car has water in the floor of the front passenger seat and nowhere else.
I tried to move the headliner so I could look for a way to drive the glass manually, but it's not easy. The liner is loose all the way to the back seat, but I can't get to the motors without bending it.
I decided to try to check the fuse. What a job! I finally found the fuse box. I don't know if I can actually touch the fuses without joining a Chinese acrobat team, but I'm going to try again later. I can't believe Ford would manufacture something this crazy.
Is there a way to move the glass back (or clear the drain lines) without a working motor?
I subscribed to Mitchell's help site.
