uberninja
- July 28, 2013
- Monroe, Wisconsin
- 1994 Ford Explorer XLT
My 94 Explorer is leaking coolant, but today my puddle was larger than normal. It is leaving a puddle by the passenger firewall. I already replaced the water pump, lower radiator hose, radiator, and radiator caps. Those appear to be on holding tight. Radiator cracked last winter, so I've been slowly replacing bits as it really only gets winter use.
When I popped the hood today, I noticed that there was coolant puddling near the spark plugs, and a few drops on the top side of the water pump. Truck runs and drives fine, it doesn't hesitate or anything. My question is what should I look into next? Intake manifold cracked or leaking? I was thinking about doing thermostat and coolant temperature sensor as well because they're cheap and easy.
Appreciate any and all help. Just don't want to keep leaving a mess on the curb!
