planchedenieve
- March 20, 2009
- Logan, UT
- '94 4.0L XLT
I have a 1994 explorer 4.0L manual transmission.
For the last while the engine has been having some problems and seem to be getting progressively worse, here are the symptoms:
-Has a semi-hard time started up, but then idles just fine.
-When I put it into gear and start to go the engine will die out. Not just lose power, but the RPM's will jolt down like it's firing bad.
-I can rev the engine in and out of gear with no problem, but when I put a load on the engine it cuts out.
It seemed to me to be problem with the ignition system so I replaced both the wireset and the distributor with no change. It's to the point now where I can't even move it.
Any help is appreciated, thanks.
