pugsy
- October 10, 2005
- Toronto, ON
- '92 XLT 4x4 (4 door)
Just saw a puddle under the back of the Explorer this morning. The line that runs from that splitter (splits to left and right drum) on the left is leaking and pedal is mushy. I haven't run out of fluid in the resevoir so the fronts will be okay from a bleeding sense right?
As for the rear, the line that runs on the frame rail seems to be okay, just a leak on the line that goes to the driver side drum. Do you recommend I fix both lines (the left drum line and the right)?
Never done brake lines before - what has to be done to remove the old linesand once the new ones are connected? Ie. how do you bleed the system and where's the bleeder holes?
Are these lines I need to replace standard pre-bent and fit? Or will I need to do some bending?
Thanks - input fast would be great!! Hoping to fix today.
