greenreddew
- October 30, 2014
- Lehighton, Pa
- 2001 Explorer
Hello.
Please bare with me while I try to explain the best I can. We have been trying to figure out the lack of power since getting the truck a couple years ago.
When we run the scanner, we get these:
P0301: Cylinder 1 Misfire Detected
P0302: Cylinder 2 Misfire Detected
P0303: Cylinder 3 Misfire Detected
P0304: Cylinder 4 Misfire Detected
P0305: Cylinder 5 Misfire Detected
P0306: Cylinder 6 Misfire Detected
P0171: System too Lean (Bank 1)
P0174: System too Lean (Bank 2)
We have changed spark plugs, wires, box thing, o2 sensors, ignition coil, throttle position sensor, and maybe a couple other things I can not think of.
We are stumped at what the issue could be. It has no power going up hill and depending on the hill, will lose speed. It also is super rough in the morning starting up. it will sputter on first start up especially cold mornings but will be fine the rest of the day.
With winter coming, def need to get this figured out before Pa snow hits.
Thanks in advance for any help. I will try my best to explain anything else or answer questions that you may have.
