Jason94sport
- April 30, 2001
- FL
- 04 EB V8
Getting some clunking in my front end. It's getting worse. Mods are in sig. The RA bushings have been done, still clunking. I disconnected the sway bar still clunking. Driveshaft balanced & new u-joints, clunking still there. Happens at low speeds & when low speed turning. Going forward or reverse. Tie rod ends look ok. The drivers side lower ball joint looks different then the passanger side. Is there a way to visually see if that is the problem? Here's a pic:
http://community.webshots.com/photo/166437338/448769739MIVSVJ
I have jacked the front end up & I have no excess play when I try to move the tire back & forth. Brakes were done about a year ago. The bearings were repacked.
I am out of ideas.
I am out of ideas.
