brandonf51780
- January 3, 2012
recently I had a problem with the fuel pump on my 1993 ford explorer. The pump did not kick on. After replacing the fuel pump it still did not start. When i played with the relays "ECC and Fuel pump". plugging the in and out with the power on, I finally heard a click in the relay and truck started. Moments later the truck is stranded again. I am unable to replicate the relay "kick-in".
Could this be a wiring issue?
I have swaped relays around in the box several times to no avail....
What should i look for?
voltage at relay is- North plug 12v - West plug 12v (when key on)
at inertia switch 7v ?????
