Help! Horrible front end sqweak! | Ford Explorer Forums - Serious Explorations
RyansX
Tulsa, Oklahoma
1998 Explorer XLT
Alright so I recently noticed that whenever I hit a bump, turn the steering wheel at all, or gas or brake hard the front end starts sqweaking! So I had my dad rock the truck from side to side while I was underneath the front end to try to find the problem. It sounds like the T-bars? It annoys the piss outta and I'd like to fix it! Any help would be appreciated! Thanks!
it is probably the lower ball joints. Could be the lower control arm bushings also.
replacing the lower control arms should fix it. Rockauto has a good price on motorcraft replacements. Avoid moog, and raybestos.
You will most likely need an alignment afterward.
his can also happen when you get sticks/wood behind your heat shield on your brakes. I get it a bit after being out bush.
I use WD40 on my sway bar bushings to stop the noise
