when I do jump it with a paper clip will I hear a noise or something?
You will see the front of the compressor clutch start turning (if the engine is running).
I made a u-bend with a piece of 10 gauge (solid) copper wire and hammered it flat on both ends to make a jumper. The copper makes a better conductor than a paper clip and you can hammer it as flat as you need to so it will fit. Of course, I'm assuming the holes are slots, not round.
Now, about R-134; Freon is a brand name, but I wouldn't stop the conversation to explain that, as if you're going to get all confused if somebody calls a refrigerant a Freon. R-134 has a pressure of 70 PSIG at 70 degrees F. The low side switch cuts out somewhere between 20 and 40 PSIG. Therefore, if the clutch switch is open, the pressure in the car is less than the pressure in the can. It is only when the pressure in the car gets up to 50 or 60 PSIG that you would find it convenient to have the compressor running to suck in the last of the refrigerant quickly. If you can't get the refrigerant to flow out of the can at all when the switch is open, you have a different problem. That problem is usually about the adapter which is supposed to pierce the can and allow the refrigerant to come out.
