Spdrcer34
- March 14, 2002
- Bremerton, WA
- 1992 Explorer XL
PCV is NOT used to recycle the unburned fuel (?) back to the engine.
PCV = Positive Crankcase Ventilation, so in other words, it is a 'Controlled Vacuum Leak'. What you had was a uncontrolled Vacuum Leak. And quite a sizeable one at that. That hole is nearly 1" in diameter. I would re-install the PCV, clear the codes, and see if you STILL have a Check Engine light coming on.
And the system that you described as, "I somehow understand that it is used to recycle the unburned fuel (?) back to the engine" That is the EGR system. Which stands for Exhaust Gas Recirculation. It helps burn fuel that would be otherwise unburnt. If the EGR system is not in place the fuel would burn in the catalytic converter, possibly shortening the life of the cat.
Ryan
Ryan
