Yesterday I replaced my pinion seal. I marked how drive shaft was bolted up and noted how many threads were showing on pinion nut (4 threads). I changed seal put back together , tightened until 4 threads were showing, and put drive shaft back were it belonged, filled with synthtic 75w140 gear oil. SO, yesterday I drove the car home from were I worked on it(4 miles). Seemed everything was fine. Then today i drove and got something to eat. Decided to take the interstate home. As soon as I hit 70 a bad roaring, and anything over 70 roared. So i went a few miles on interstate and exited and took the back way home, making sure I could make it home. After I got off interstate the rest of the way home there was a small vibration. But it was not much of a vibraton. SO, is it to late for my rear end. A pull your own parts place gets 280 dollars for a complete axle w/rear end assembly. Seems thats the easiest route to take if its not saveable. I went estimated 20 miles since changing seal.
