Help Identifying Electronic Module | Ford Explorer Forums - Serious Explorations
elektaus
Buffalo, NY
96 Eddie Bauer
Hi All,
Started hearing a rapping noise comming from the glove box the other day. It turned out to be a small (3"x4") electronic module that sits just behind the left side of the glove box. I pulled the electrical connector and of course it stopped. If I plug it back in it starts again. Seems like it's an actuator of some kind.
Can anyone tell me what this thing does?
Truck is a 96 Explorer (Eddie Bauer version).
Thanks,
--E--
got a pic it'll make it easier to see what you area referring to.
After you unpluged it is there anything that does not work?
In my 99 there is a PATS module and a restraint control module in the are you describe.
Think I Found It
I believe its the dreaded blend door problem
