jmdirk
- July 22, 2004
- Ottawa, Canada
- '93
Just want to clarify some information here. I'm looking at buying a '99 Sport 4x4 with a 5 speed. Definitely a 4.0 OHV (according to the VIN and visual inspection). The door sticker has a Trasn code of 'M'
According to this link:
http://www.explorerforum.com/forums/showthread.php?t=239360
I get this:
Transmission Codes
Code .................. Model
D (1997-2005) ..... A5LDE / 5R44/55E
D (1992-1996)...... M5OD-R1
J ....................... M5OD-R1
J (2002-2003)...... R1HD / M5OD-R4
M (2000-2001)..... Mazda M5D4
M (1997-1999) .... M5OD-R2
M (1992-1996) .... M5OD-R1
R (2002) ............. 5R55W
T (1992-1995) ..... A4LD
T (1996-2001) ...... 4R55E
U ....................... 4R70W
V ....................... 5R55S
X ....................... 6R60
Now my understanding is that the M5OD-R2 was used in the F-150 and has a different bellhousing bolt pattern etc than the M5OD-R1.
This link:
http://www.explorerforum.com/forums/showthread.php?t=185171
says that the M5OD-R1 is the only manual transmission used in the Explorer (at least pre-2000).
The Mitchell On-demand repair info also states that it should be an M5OD-R1.
I'm planning on swapping this tranny into a 93 and want to make sure I'm not buying something that won;t be compatible. (I don;t want to swap the whole engine in since I just finished rebuilding the engine after hydrolocking it last year)
Can anyone (perhaps with a '99 Sport 4x4 manual) provide some additional insight?
If the main Transmission and Axle code page is wrong, perhaps we can get it updated and corrected?
I get this:
Transmission Codes
This link:
