Alf - The electronic cleaner is good.
Also, like the others already said, you don't HAVE to have the tune. The size of the 73MM C&L MAF housing is just a tad bigger than the stock MAF housing on your truck.
However, the true story is, you now have a bigger MAF housing and the air rushing by that stock sensor will be at a different rate than stock. What this all means when you don’t have a tune is this;
1) The PCM will be determining the amount of fuel to add based on the air rushing by the stock sensor.
2) The air rushing by the sensor will be a tad slower than the stock tune is set-up for.
3) The result will be a VERY small discrepancy in your actual air/fuel measurement. It’s WAY too small to worry about, and if it was a problem, your truck will throw a code. (It won't)
Now, say you buy a 75MM C&L MAF housing. This WILL result in a code because this housing is too much for the stock tune.
