porta1
- April 15, 2014
- 2001 Ford Explorer Sport
Hey all - hoping someone can give me an idea if my explorer is fixable or not.
It is a 2001 Ford Explorer Sport - 4.0 SOHC. 185k miles, last oil change in October, about 4k miles ago.
My wife was driving the car and she heard a thunk and it died on her. Coasted to the side of the road, so we had it towed home. It won't start, but it does attempt to turn over (though it doesn't sound "right". sort of chugs in one tone, without any cyclical rhythm that you'd expect while cranking).
Before this incident, it should be noted that the car was making a TON of top end clatter - I was waiting for the weather to clear up to look into it, but I guess luck was not our our side.
Upon inspection I can see that part of the valve cover on the back side of the engine, right up against the firewall, has blown out - and there is what I gather is a camshaft/timing chain clearly visible through the hole.
Dipstick indicates there is oil in the engine still, so it hasn't all blown out, but I can see oil stains where it has sprayed out...
I've spent hours researching and reading posts and from what I can tell, I must have lost a chain tensioner/guide, or the chain slipped, or some other object got in there and caused the hole.
What is not clear to me is:
1. Is this a DIY fix involving just replacing the valve cover and tightening/replacing the chain?
2. Is pulling the engine required to fix this? (the car is only worth probably 1000-1500 while running, so pulling/replacing the engine is likely a no go for us, as it would likely be very expensive? I do not have access to an engine hoist/mount)
2. should I bother doing a cold compression test on all 6 cylinders? I have a compression gauge, but if we can tell that the engine is blown I'd rather not take the time
Thoughts? Is this car junkyard bound or can it be fixed?
Thanks!
Thanks!
