mainiac1
- April 18, 2013
- Florida
- 2001 Ford Exporer Sport
Hey guys, started replacing the lower and upper balljoints on my 01 explorer sport 4wd. Balljoint install tool kit from autozone didnt fit the top of the lower a-arm very good...had to improvise a metal sleeve the right size since I was using the right size on the bottom of the new balljoint. Replaced these on my 01 silverado no problem, but this lower one was really tight. Got it 1/2 way in with alot of effort. I did check it a few times to make sure it was coming up into the hole straight and it was. Thought I got it seated using 1/2" braker bar....but what I did was cut the seal and bend the lower flange of the new Raybestus ball joint p/n: 505-1281B from Rockauto and it still wasn't seated!!! I know the uppers you have to replace the whole a-arm, but what did i do wrong on this lower? old one had a c-clip like you could replace it. If the lower a-arm is not serviceable (have to replace it rather than replacing the balljoint, how can I tell? Is there a specialty tool that I need to replace these lowers? Also just noticed the upper passenger side a-arm I ordered is the non-adjustable type, yet mine has the adjustable upper a-arm....I guessing I need to send this one back and buy an adjustable upper...? Apreciate your help.
Jamie
Jamie
