HELP Lighting troubles | Ford Explorer Forums - Serious Explorations
I did the "Brighter Headlights" on my 1994 limited, I ordered some higher wattage PIAA's and the extension harness and everything worked fine for a few weeke. Now my headlights do not always come on, I have to toggle the bright /Dim lever to get them to come on now, this afternoon they do not come on at all !!!!!! YIKES
Where is the headlight relay...sounds like a sticking relay to me , it is the same if I use the automatic headlight function on my mirror or I pull out the head light switch the old fashion way.
THanks
Dwight
On 1994 (1st Gen) Xs it seems the headlight switch itself has been the cause of most of the headlight problems. Most folks with a problem report that the switch is blackened/melted.
