Help needed. (coolant leak) | Ford Explorer - Ford Ranger Forums - Serious Explorations
63pala
Woodbridge NJ
2003 ford explorer XLT
I'm having a coolant leak, but i do not have a part # nor I have a name for the spacific hose. I tried to explain the local autozone, but no luck.
can some one help me identify this hose and if you have a part# can you please post it.
The leak is located on the passenger side, the hose goes from the water neck to the heater core I believe through a "T" and that's were is leaking at the T.
Thanks.
Having a hard time uploading a picture, hopefully this works.
63pala
Woodbridge NJ
I guess I didn't work, let me try this again.
05XLimited
Boozburg, PA
2005 Limited V8
Does it have rear HVAC controls?
unclemeat
Richmond, VA
91 sport
That is a heater hose. It comes with the Tee intergrated into the hose. I do not have the part number handy. You can look it up on Rock Auto. They have the best price.
63pala
Woodbridge NJ
Yes it does have the rear HVAC controls, I will look it up on Rock auto.
63pala
Woodbridge NJ
I looked in Rock auto, but the one that shows, has a small diameter hose at the TEE, the one in my car the diameter is all the same size.
Sixonemale
2015 XLT Appearance Pkg
It is a heater hose assembly. You may want to call Ford first and then look at Rockauto. I remember having the same problem that you are having, identifying the part on Rockauto. I had repair shop perform the repair and they listed the price of part at around $200, and I think they purchased it from Ford and now that I think about it, they may have had to wait for the part to get shipped in. It's a spider web of hoses all attached together.
63pala
Woodbridge NJ
I was thinking on cutting the plastic "T" off and put a Barbed copper Tee fitting with hose clamps, that might be easier to do and cheaper.:D
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
:thumbsup: Beats getting gouged on genuine Ford or Motorcraft prices. Only concern is that the hoses appear hard and brittle.
05XLimited
Boozburg, PA
2005 Limited V8
Looking at the Ford Parts website, the part that it appears to be is:
18B402 $121.54
(KT-78)
Ford
HVAC Heater Hose Tube
4.0L V6 12V Single Over Head Cam EFI Less Engine Oil Cooler With Aux Overhead Heater And A/C All Left Hand Drive Territories
That was the reason for asking about rear air. The non-rear air has no T in the hose.
63pala
Woodbridge NJ
Thanks for the helpful links, and part #s much appreciated.
Today, I got me a long heater hose of the same diameter and some fittings. hopefully I can fix it this weekend. I will post a picture of the end result.:chug:
63pala
Woodbridge NJ
Ok, fixed it no leaks and it cost me $18.00 :D
Here is a picture of the new repair, don't mind the lil of coolant that spilled on the engine.
And here is the old Tee.
Thanks guys for all the help. :chug:
home4sale2
Chicago, IL
2002 Explorer XLT 4.0L V6
Thank you, where did you get the Tee, part numbers?
