http://www.explorerforum.com/forums/showthread.php?t=212283&highlight=remove+strut
1 - remove tire
2 - disconnect the stabilizer bar link at the lower control arm
3 - remove the bolt from the lower control arm to the knuckle
4 - remove the 3 nuts at the top of the strut (not a lot of room but not bad)
5 - remove the bolt at the bottom of the strut
6 - push the lower control arm down as far as it will go
7 - remove the strut
Thanks to "tower" who posted this information I was able to change them out this weekend. Thew first one took quite a while - until I found this info posted above! Second one took about 30-45 minutes.
This could be a 2-man job, one to use a crowbar or whatever to push down the control arm and one to wrangle out the strut, but I did it myself.
You do not need spring compressors - they do nothing to compress the length. Trust me, I tried...
You NEED to remove BOTH the stabilizer bar link nut (step 2) AND the bolt from the lower control arm to the knuckle (step 3) or esle there will not be enough room to remove the strut. You do not need to remove the Toe Link bar.
There are some good diagrams on Autozone.com in the repair guides section.
Also - the springs did not appear to be broken at all... but the rear end sits much higher now and rides very nice!
ND
