Abchameleon
- June 10, 2018
- Dayton, oh
- 04 ford sport trac xlt
04 ford sport trac xlt 4wd auto. Speedometer and cruise control not working. Check fuses all good. Replaced vss on rear diff did not fix, sent instrument cluster for repair all other gauges work speedometer Still not working. No check engine light, no codes when scanned. Could the output sensor on transmission be the issue? When i went to part store for vss they originally gave me part on transmission but I was told the vss is actually the one on rear diff that was replaced. Transmission is shifting fine. Side note the 4x4 low light does stay on dash but I have never used 4 wheel drive not sure if this would be connected. Major concern is speedometer.
