gsmann
- October 26, 2010
- Atascadero Ca.
- 97 Aerostar
I have a 97 Aerostar. A front wheel bearing failed so I replaced that spindle all wheel bearings and brakes. When I went to drive the car again it had no Brake lights, turn signals or E flashers. I am pretty sure that the multifunction switch failed as this was the first time I had used the E flashers.
I have located a used steering column and will probably just change the whole thing instead of just the switch as the books say you have pull the steering column to change the switch.
Anybody out there know where I can find good instructions for doing this ( Haynes and Chiltons are worthless)?
