70GS455
- August 8, 2005
- Huntsville, AL
- '97 Mountaineer
I've had an oil leak out of my 16 y.o. son's 97 5.0 Mountaineer for a few days now and decided to check it out. While under it, I noticed a hairline crack in the oil pan, about 2 inches long, directly above (and parallel to) the power steering rack/pinion cylinder. It was still warm and leaking pretty good. I added 3 quarts to get it to the "full" line. I put a pan under it and checked it this morning and didn't leak very much at all overnight (maybe 1-2 tablespoons?). So what can cause this? How do I need to fix it? Pull the engine, or just weld it from the outside? TIA.
