Help on a 95 xlt with loss of power and overheating?
Eturpel
Chicago
'95 XLT 4x4
Greetings...hoping someone will read this and be able to help.
I replaced the transmission about 2 weeks ago...prior to that, my 4.0l V6 4x4 sat for over 6 months through the cold and rain, etc. It starts...but loses power constantly. If in idle It'll go to 2k RPM then back to 1k a few times...if I let it sit while started a while it eventually dies. I have since replaced the spark plugs, the radiator fan clutch, 50/50 fluid, trans fluid, thermostat and manifold gasket. I'm still having the same problem, and if I drive it for about 20 minutes it will say it's overheating, but the engine doesn't seem very hot..I don't get it.
I see no water coming from the bottom so I assume my water pump is okay...what's my next step?
V 1999 XLT Problems...Please Help Stock 1995 - 2001 Explorers 8
P Solved 98 xlt crank no start. Please help Stock 1995 - 2001 Explorers 11
Z 1999 XLT 4.0 v6 SOHC need help trouble shooting Stock 1995 - 2001 Explorers 11
Whitfield Explorer XLT 2000 with issues - help please Stock 1995 - 2001 Explorers 42
N 1997 Explorer XLT ControlTrac 4wd Issue - HELP Stock 1995 - 2001 Explorers 21
G 96 Explorer XLT instrument cluster lights issues, HELP! Stock 1995 - 2001 Explorers 6
A Need help with understanding 1995 Explorer XLT EEC OBD1 Code(with video) Stock 1995 - 2001 Explorers 5
B 96 Explorer XLT wiring behind dash help Stock 1995 - 2001 Explorers 0
E [98 Explorer XLT 5.0] (Another) Turn Signal Problem, Replaced Everything, Please Help Stock 1995 - 2001 Explorers 2
N New to me '98 XLT 5L. Manifold choice help Stock 1995 - 2001 Explorers 6
F 96 explorer xlt, 4wd not working, help! Stock 1995 - 2001 Explorers 1
B 1996 Explorer XLT-AC vent problems HELP! Stock 1995 - 2001 Explorers 1
ProjectAviator 98 Ex XLT 4.0 not startig??? Help Stock 1995 - 2001 Explorers 2
H 97 xlt 5.0 no start help Stock 1995 - 2001 Explorers 0
J 97 XLT (4.0 sohc)... Not starting.. Any help appreciated Stock 1995 - 2001 Explorers 8
J 97 xpler xlt 4wd 4.0 sohc help Stock 1995 - 2001 Explorers 3
R '98 XLT 2wd 4.0L needs trans and run help Stock 1995 - 2001 Explorers 1
B Need help. I have 1998 explorer XLT that will not start. Stock 1995 - 2001 Explorers 4
B 2000 Explorer XLT, problem with P.A.T.S.!! HELP!!! Stock 1995 - 2001 Explorers 2
redexplorer5.0 im new to this please help 1998 ford explorer XLT 5.0 AWD right upper control arm Stock 1995 - 2001 Explorers 10
G 97 Ford Explorer XLT V6 4.0L SOHC P0351 HELP Stock 1995 - 2001 Explorers 3
K Shocks 2000 4x4 xlt - help choosing Stock 1995 - 2001 Explorers 8
S 97 Ford Explorer XLT 4wd AT --Tranny problem, help? Stock 1995 - 2001 Explorers 10
M Help! 96 Explorer XLT Lost 4th gear Stock 1995 - 2001 Explorers 9
J '96 Explorer XLT V6 4x4 Idle.. Oh my! Major issue! HELP Stock 1995 - 2001 Explorers 0
S help with putting new alarm in my 96 xlt Stock 1995 - 2001 Explorers 1
S help with window relay on 96 xlt Stock 1995 - 2001 Explorers 0
P 96 XLT seat belt repair help Stock 1995 - 2001 Explorers 17
T Ford Explorer XLT help please. Stock 1995 - 2001 Explorers 2
N mexican guy needs help with 4x4 explorer xlt 1996 front lockers dont work Stock 1995 - 2001 Explorers 1
A Help with 96 ford explorer xlt amp bypass.. Stock 1995 - 2001 Explorers 1
O 96 ford explorer xlt engine vibration help please Stock 1995 - 2001 Explorers 10
9 help plz.. 96 exp xlt 5.0 Stock 1995 - 2001 Explorers 16
S 97 Exp. XLT - 4x4 won't turn on - Need help Stock 1995 - 2001 Explorers 0
L Low idle problem help please! 2000 ford explorer xlt Stock 1995 - 2001 Explorers 5
B 2000 ford explorer xlt motor help Stock 1995 - 2001 Explorers 3
C 1998 explorer XLT air conditioning problem (electrical?) help please! Stock 1995 - 2001 Explorers 5
B Help! 99 XLT- possible short? Stock 1995 - 2001 Explorers 4
E help with 99 XLT SOHC muffler replacement Stock 1995 - 2001 Explorers 0
E 98 SOHC Enigine swapped in 97 XLT 4X4 WONT START PLEASE HELP!! Stock 1995 - 2001 Explorers 7
J Help turning off Rear Wipers on 98 XLT Stock 1995 - 2001 Explorers 4
S 96' XLT problem need some help Stock 1995 - 2001 Explorers 2
K 98 xlt 4.0 help Stock 1995 - 2001 Explorers 0
R 95 Explorer XLT ALARM locking the starter? HELP!! Stock 1995 - 2001 Explorers 3
R 95 Explorer XLT. The alarm is locking the starter. HELP! Stock 1995 - 2001 Explorers 2
D 2000 XLT W/ Electrical Problems Help!! Stock 1995 - 2001 Explorers 23
S HELP! Non functioning fuel system on a 99 Explorer XLT. Stock 1995 - 2001 Explorers 3
C i need some help with my 97 xlt Stock 1995 - 2001 Explorers 0
G 1997 XLT Air bag reset HELP! Stock 1995 - 2001 Explorers 11
G Alternator help is needed on a 99 XLT. Stock 1995 - 2001 Explorers 5
Similar threads
