Help on Cam Shaft Position Sensor Replacement ?
Watchman
Virginia
1993 Explorer Sport-4WD
I had a shop replace my Cam shaft Position Sensor earlier this year om my 93 ex and I am now getting a 214 code. I replaced the original with a Dorman 689-110. So I'm thinking that this Dorman unit is bad. Less than 5K miles.
Is there is a more robust replacement > PLease help..
92exp4x4
Covington, Kentucky
92 XL 2-door and others
Check out rockauto.com. They may have a motorcraft part available. I try to use OEM as much as I can.
